warsawtech
Jul 11, 2019Tutor
Unable to change Notification Email Address
We have been trying for a month to either change the login email address or at least the notification email address within our Insight account. We have multiple addresses and while we use our main ad...
MrJoshW
Jul 30, 2019NETGEAR Employee Retired
You can change the Insight login email under the account settings of Insight. Once you log into your account on the top right hand corner select the profile icon and navigate to update profile. From there select login settings and change email. After you change the email you will receive an email under the new email address confirming that you wish to change the login email to the new email. After you have clicked accepted you can now log in with the newly changed email. Hopefully this helps.
warsawtech
Jul 30, 2019Tutor
We have tried that. We get to the point where Insight populated with an error code for a fraction of a second, logs us out then when we try to log back in, no changes have been made.
- MrJoshWJul 30, 2019NETGEAR Employee Retired
If you can, send me a private message with both emails and I can take a look in the backend which one is registered.
