Dolly5
Aug 26, 2019Follower
Where to a find my PIN or security key
Good Evening, I purchased my router several years ago. I just got a laptop and it is requesting that enter a PIN or connect using a security key instead. I have to idea how to obtain either or where t...
schumaku
Aug 30, 2019Guru - Experienced User
The PIN would be a WPS PIN - the security key is the same password as you would enter for adding another system e.g. a mobile to the router.
Pretty much unrelated to the community section - your router is unlikely Netgear. Insight managed.
