ALIAYDAN's avatar
ALIAYDAN
"add interface ip error " M4250-40G8XF-PoE+
Hi all
If any one can help I have switch M4250-40G8XF-PoE+ I edit the default VLAN and add a static IP it works fine then I tried to add a video VLAN the VLAN created but not allow me to add the static IP for this VLAN and give me this error "Add interface IP error" I tried multiple ways but no luck.
thanks
  • schumaku's avatar
    schumaku
    More than just vague.
    Different from the Netgear Smart Switch models. the managed switches don't have a default video VLAN to start with.
    All these switches are coming with various acccess and management vectors, the IT Web Admin UI, the AV Web UI, the CLI, SNMP, the Engage Controller, the API, in-band, and out-of-band management, ...  The minimum to reply would be including the model, the firrmware version, the "where" and "how" you try to define an interface IP address in a VLAN.
    Please be so nice and tell us a little bit more here. Of course, Netgear is happy to offer thier top-notch Pro AV network design service via proAVDesign@netgear.com.
    • ALIAYDAN's avatar
      ALIAYDAN
      I just logged in to the switch via "AV UI Login" and went to network profile, select video profile and proceed with wizard, entered the vlan ip address, after apply the vlan created but without IP and and give me this error "add interface ip error"
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
ProSupport for Business
