DOHEELEE
Jul 09, 2023Aspirant
Can the current switch structure be changed to a mesh configuration?
We have a switch configuration in a tree structure consisting of M4300 24XF-Nodal -Fiber, M4300 24X-Nodal -RJ45, M4300-52GPOE Control -MediaServer, M4250 26G4FPOE Control-OpRoom, M4300-52GPOE-Dante, ...
DOHEELEE
Jul 10, 2023Aspirant
First of all, I'm not a networking expert. Currently, our network topology is configured in a tree structure using M4250 and M4300 switches. However, for some reason, we are experiencing network issues that cause the entire network to go down.
As a brief thought, although it may not be a fundamental solution to the problem, I wondered if changing the network topology from a tree to a mesh could potentially allow for transmission to be routed to the other side in case of issues on one side.
schumaku
Jul 10, 2023Guru - Experienced User
The beauty of these managed switches is the availability of a complete logging and management capabilities. Lack of insight, hard to guess what is going wrong.
Don't hesitate to contact the Netgear ProAV Design Support to get assistance.
Of course, considering you have enough high bandwidth ports available, you could consider to configure some redundancy on your network using some clever spanning tree config for example This is more for the case if one of the tree configured switches devices would go down.
- DOHEELEEJul 10, 2023Aspirant
That's correct. Since I'm not sure what the problem is, my current questions are focused on finding ways to avoid the problem rather than solving it.
I will look into the spanning tree structure further. Thank you for your answer
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
