ryanmonge
Dec 18, 2023Follower
Is there an option for offline configuration?
Our company sets up its systems in our warehouse before we begin installation. We typically configure our switches at that point. It would be helpful to be able to set up a configuration file before ...
schumaku
Dec 19, 2023Guru - Experienced User
LaurentMa wrote:
I think this would be very easy. Configuration files can be prepared on a switch for instance, using our AV UI if this is an AV application, or the IT GUI if this is more of an IT application.
Said that, there is no UI emulator available to generate configurations without unpacking a physical switch.
LaurentMa
Dec 19, 2023NETGEAR Expert
Never say never! We know it would be a very good idea. Cheers
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
