glvideo
Apr 07, 2022Aspirant
M4250-12G2XF-PoE+ Problem lost link on a trunk link
Hello, I have a problem using a M4250-12G2XF-PoE+ along with a M4250-26G4XF-PoE+. Issue : works well for some times (30 mins or 2 hours) then connection is lost on the trunk link Both swi...
glvideo
Hi,
Thanks for the quick answer.
SFP not certified yet showed as "Supported" on the switch.
But yes, prone to incompatibility i guess.
File sent via email.
Thanks a lot
schumaku
Apr 08, 2022Guru - Experienced User
Allow some notes here:
Is there no indication in the logs (on the IT view) why the link was disabled?
Most makers and vendors sold and still offer 10GbE copper modules wiy limited reach only (like max 30 m, sometimes 35 m), due to high power requirements of the earlier chipsets). The reason LaurentMa pointed to the -200000 version because it's providing longer reach.
- glvideoApr 08, 2022Aspirant
Hi,
thanks for the insight.
the module is effectively getting pretty hot, don't know if it is expected.
Can't say more from the IT point of view.
Thanks
- schumakuApr 08, 2022Guru - Experienced UserSo no potential related items in the device log?
From wally brain these cli commands show some basic insightof the SFP modules:
# show fiber-ports optics all
# show fiber-ports optics-info all
#show fiber-ports optics-eeprom 1/0/1 (this is unit/slot/port
or
#show fiber-ports optics-eeprom all- glvideoApr 08, 2022Aspirant
Sorry misunderstood your first question.
NETGEAR support team certified there is a "local fault" error on port 12 (SFP) of the M4250-12G2XF.
Though it only appears on this switch, never on the M4250-26G4XF on the other side.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
