IainPoole
Sep 07, 2023Follower
M4250-40G8XF-PoE+ - Will not allow Airplay when Configured for Crestron NVX
Having issues with the above switch works amazing for Crestron NVX and AEX-67 audio, but when trying to Airplay to the Crestron DM-NAX = which has enabled Airplay zones Apple TV's plugged into Sa...
agizem
Oct 02, 2024Aspirant
Hey mate,
I'm having issues with getting the NVX to work with the same switch on network profile video with AE67. Did you have to do any other extra step in config? what range is your multicast address?
- LaurentMaOct 02, 2024NETGEAR ExpertI just responded to your other thread! Kindly check
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
