IainPoole
Sep 07, 2023Follower
M4250-40G8XF-PoE+ - Will not allow Airplay when Configured for Crestron NVX
Having issues with the above switch works amazing for Crestron NVX and AEX-67 audio, but when trying to Airplay to the Crestron DM-NAX = which has enabled Airplay zones Apple TV's plugged into Sa...
LaurentMa
Oct 02, 2024NETGEAR Expert
For AirPlay, mDNS Bonjour needs to be in the same VLAN. So WiFi clients needs to be in your NVX VLAN. If they are not, you need a mDNS gateway replicating Bonjour across VLANs. NETGEAR Insight Access Points and PR460X router can do that for you, for instance. Feel free to email us at ProAVDesign@netgear.com for help!
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
