Bliebs77
Feb 21, 2020Aspirant
M4300-96X Stacking over 40GB
Hello- I have 2 M4300-96X switches both running 12.0.9.4 firmare and I am trying to stack both of them together over the 40GB fiber link. I can successfuly stack them over Cat6a, but every time ...
LaurentMa
Feb 21, 2020NETGEAR Expert
Thank for your message and sorry for your issue. As I understand it, your 40G ports work in Ethernet mode but not in Stack mode. It may be related to the fiber modules in use which aren't supported in Stack mode. The tech support file out of one your 96X switch will help us understand the exact cause of your issue. I have escalated your post and the NETGEAR team is going to be back to you shortly. We shall fix your issue!
- Bliebs77Feb 21, 2020Aspirant
Laurent; thank you for the reply.
I have the APM-402XL Modules in each switch using Cisco QSFP-40G-CSR4 SFP's.
The case number is 42333781.
Thank for you the prompt reply!
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
