mediazone
Nov 28, 2023Aspirant
POE++ Injector with M4250
Hello, I have a M4250 with POE+ 3 of my cameras need POE++, is it possible to use a POE++ injector with my M4250 and still pass thru NDI Video? I know there are POE++ switches available, but ...
schumaku
Nov 29, 2023Guru - Experienced User
Yes, of course. This is the advantage of industry standard PoE (vs. proprietary passive PoE). The M4250 won't provide power if there is no compliant PD (powered device) - so there is no added risk people are often concerned. The plain Gigabit Ethernet connection will be retained "through" the power injector. What you are loosing is the network-side control of the power on these ports.
mediazone
Nov 29, 2023Aspirant
Thank you, so if Im understanding correctly, a PTZ camera will lose the control functions?
- schumakuNov 29, 2023Guru - Experienced User
No, of course not. The PTZ controls are almost certainly embedded in the Gigabit Ethernet data stream.
What you can't do is eg. triggering a power reboot in case your device will hang one day,
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
