psda
Jan 03, 2024Aspirant
Problems creating reserved IP address in a DHCP Pool
We created a pool of reserved DHCP IP addresses under an older firmware release (13.0.4.13). We've upgraded to 13.0.4.17 and are now trying to both update existing reservations and add new reservat...
LaurentMa
Jan 03, 2024NETGEAR Expert
Hi psda ,
Sorry about this issue, maybe there is a conflict somewhere else - can you edit your config file or do a show run like I do below, to show your static pools and your VLAN interfaces? Alternatively, please send your tech-support file (Diagnostics\Support Diagnostics to ProAVDesign@netgear.com) with a link to this post and one of our SEs will help you.
On my side, using the latest NETGEAR Engage Controller (www.netgear.com/engage) and creating a VAN 10 with your IP scheme, I can create plenty of static pools easily in Engage (Site Settings\VLAN Routing and DHCP Server\Advanced\DHCP Reservations):
interface vlan 1
routing
ip address 192.168.253.1 255.255.255.0
exit
interface vlan 10
routing
ip address 10.4.0.1 255.255.255.0
exit
ip management vlan 1 192.168.253.1 255.255.255.0
router rip
exit
service dhcp
ip dhcp excluded-address 192.168.253.1 192.168.253.9
ip dhcp excluded-address 192.168.253.101 192.168.253.254
ip dhcp excluded-address 192.168.20.1 192.168.20.99
ip dhcp excluded-address 192.168.20.201 192.168.20.254
ip dhcp excluded-address 10.4.0.1 10.4.0.99
ip dhcp excluded-address 10.4.0.201 10.4.0.254
ip dhcp pool "pool_dynamic_1"
lease 0 4 0
dns-server 8.8.8.8 4.4.4.4
default-router 192.168.253.1
network 192.168.253.0 255.255.255.0
exit
ip dhcp pool "pool_dynamic_10"
lease 0 4 0
default-router 10.4.0.1
network 10.4.0.0 255.255.255.0
exit
ip dhcp pool "aabbccddeeff"
hardware-address aa:bb:cc:dd:ee:ff
host 10.4.0.101 255.255.255.0
netbios-node-type b-node
exit
ip dhcp pool "aabbccddeeaa"
hardware-address aa:bb:cc:dd:ee:aa
host 10.4.0.102 255.255.255.0
exit
exit
- psdaJan 03, 2024Aspirant
I'm using the main UI and not the engage controller. I experimented with the engage controller and DHCP reservations but these only work if the controller is running and that isn't a viable scenario for our config.
What show option is dumping out the info you displayed above?
- LaurentMaJan 03, 2024NETGEAR Expert
Can you do "show run" after "enable" so in global admin mode, and copy paste the end of the config here, like me, starting with the VLAN IP interfaces, and all the DHCP services under?
I emailed the info you requested to ProAVDesign@netgear.com
Note: the RDL entry is one that reports the error. However, all new ones that I create report it also.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
