psda
Jan 03, 2024Aspirant
Problems creating reserved IP address in a DHCP Pool
We created a pool of reserved DHCP IP addresses under an older firmware release (13.0.4.13). We've upgraded to 13.0.4.17 and are now trying to both update existing reservations and add new reservat...
psda
I'm using the main UI and not the engage controller. I experimented with the engage controller and DHCP reservations but these only work if the controller is running and that isn't a viable scenario for our config.
What show option is dumping out the info you displayed above?
LaurentMa
Jan 03, 2024NETGEAR Expert
Can you do "show run" after "enable" so in global admin mode, and copy paste the end of the config here, like me, starting with the VLAN IP interfaces, and all the DHCP services under?
- psdaJan 03, 2024Aspirant
I emailed the info you requested to ProAVDesign@netgear.com
Note: the RDL entry is one that reports the error. However, all new ones that I create report it also.
- LaurentMaJan 04, 2024NETGEAR Expert
All right, we'll take it from there!
Several problems below that we will address together with the ProAV Design team and you:
- Your IP schemes are Class C with 255.255.255.0 but so far with an exclusion spanning across different Class C subnets
- Client-identifier shouldn’t be used (it’s for other DHCP options, here we do MAC reservation)
- Default-router is needed to me, in the main dynamic pool to be bound to VLAN 160, and in any static pool for correct binding as well
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
