Retired_Member's avatar
Retired_Member
Sep 25, 2021
A little help - Orbi Pro SRK60 WAN Setup
Hi,   For WAN Setup, what is the default setting? Don't want to place the router to default settings.   And in the attached screen grab, is this router at risk.  I totally forget the default sett...
  • Retired_Member's avatar
    Retired_Member
    Sep 25, 2021
    I think I found it...in the User manual....page 69
    Should have checked there first. Sorry......
ProSupport for Business
