BooJangles's avatar
BooJangles
Apprentice
Jul 24, 2020
Access Across Networks
Orbi Pro SRR60 w/ 5 wired and 2 wireless satellites.
Hi all,
Is it possible to make a single device available from both your primary Wi-Fi and Guest network? I have a scenario where a music device will need to be put on the network via wifi but I want it accessible from both networks.
All ideas welcome.
Thanks.
  • BooJangles,
    It is not possible.  Be reminded that using the Guest Network, the wireless devices connected to it cannot see each other (or any other WiFi network on the Orbi Pro System).  Also, they cannot access the local area network (LAN).
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    BooJangles,
    DaneA
ProSupport for Business
