djn5010
May 27, 2022Aspirant
Cannot access via the app but does work when i log-in through orbilogin.com
I am having this exact issue however I have a different model, SRR60 and 2 SRS60's. Can you confirm this is on your radar for a patch/fix as well?
Cannot access via the app but does work when i...
May 28, 2022Guru - Experienced User
Are you on iOS? if so, make sure to disable icloud relay and private mac/ip address
