djn5010
May 27, 2022Aspirant
Cannot access via the app but does work when i log-in through orbilogin.com
I am having this exact issue however I have a different model, SRR60 and 2 SRS60's. Can you confirm this is on your radar for a patch/fix as well?
Cannot access via the app but does work when i...
schumaku
May 28, 2022Guru - Experienced User
Dave,
So a good soul has split off your question to the Orbi Pro forum section.
The Orbi App subject on that other consumer Orbi thread was never intended to be used with any Orbi Pro devices. This was more a side-effect on the first gen Orbi Pro due the common heritage of the SRx60 with the consumer Orbi. This has changed with the newer Orbi Pro models.
Keep in mind that orbilogin.com is not any kind of a cloud access - this domain does resolve to the LAN IP while connected to the LAN/WLAN of the Orbi system.
-Kurt
