hajar1
Jul 06, 2023Guide
Cannot change any parameters via insight.netgear.com
Whenever I try to set any parameters, e.g. enable Guest wifi via insight.netgiear.com, I get the following error by email: And no changes take place. Tried both the App and the website. Wh...
schumaku
Jul 11, 2023Guru - Experienced User
BruceGuo wrote:
hajar1 we are confirming this problem. we will get back to you.
Which ones of the at least two issues please - the failure of applying a guest network config, or lack of control segregation, allowing to use the local device Web UI unrestricted?
- hajar1Jul 11, 2023GuideThank you everyone. Really appreciate you looking into it. My biggest problem that my router is insight controlled, but I cannot make any configuration changes, always resulting in the type of error I pasted a screenshot of earlier. So its like my configuration is set in stone with settings when it last worked and since then no more changes are possible. Really dreadful setup…
