hajar1
Jul 06, 2023Guide
Cannot change any parameters via insight.netgear.com
Whenever I try to set any parameters, e.g. enable Guest wifi via insight.netgiear.com, I get the following error by email: And no changes take place. Tried both the App and the website. Wh...
schumaku
Jul 11, 2023Guru - Experienced User
BruceGuo wrote:
hajar1 we are confirming this problem. we will get back to you.
Which ones of the at least two issues please - the failure of applying a guest network config, or lack of control segregation, allowing to use the local device Web UI unrestricted?
hajar1
Jul 11, 2023Guide
Thank you everyone. Really appreciate you looking into it. My biggest problem that my router is insight controlled, but I cannot make any configuration changes, always resulting in the type of error I pasted a screenshot of earlier. So its like my configuration is set in stone with settings when it last worked and since then no more changes are possible. Really dreadful setup…
