Jan777's avatar
Jan777
Follower
Sep 17, 2021
Connect router and satellite by ethernet cable
Hello
When you have two buildings, is it possible to connect a satelite by ethernet cable to the router? (cable length 130 feet)
Thank you in advance.
SXK80B4 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
1 Reply
  • plemans's avatar
    Yes you can. They support wired backhaul.
ProSupport for Business
