Flash008
May 30, 2019Luminary
Firmware 2.3.1.100
I am not sure what to say about this new firmware. My parents alway taught me, “If you don’t have something nice to say, then say nothing at all”. Yet, I was also taught, “if you have a probl...
- Jun 03, 2019
All,
We have received a list of comments from Flash008 and are reviewing them. Please note that there is nothing in the world that makes us happier than seeing happy and satisfied customers and users of our products. At NTGR, we take pride in our products and seek to please our customers.
In regards to the response that MrJosh provided, his point is that Orbi Pro was designed to be a DIY product for business owners that are not network engineers. I has the features to meet the needs of that group of users. But it looks like the success of the product, has resulted in unforseen expectations for features such as SNMP or Syslog which is not something that a small business owner would require.
in other words, Orbi Pro was not meant to replace a product like our WAC540 that has all kinds of bells and whistles.
Please bear with us as we are going through all the comments received which is a summary of all of your points and we'll have a dialogue and work through them.
Finally, we are doing our best to wow our customers, but please don't interpret this as commitment to implement features.
Orbi Pro Product Management
ThaMichie
Jun 18, 2019Tutor
Since I upgraded to 2.3.1.100 Orbi sends out 2x the same SSID of network 2.
SSID seperation for 2.4Ghz and 5Ghz is turned off.
Downgrading to the previous firmware fixes this problem, a reinstall with the new firmware does not help.
Also the Guest network just goes back to the login page when clients try to connect. Also a bug present since last firmware.
I wonder how well these "new features" are being tested by Netgear as this is unacceptable for a business device!
Please fix this ASAP as we need clients to be able to connect to our guest network and I want to get rid of the double SSID as devices are constantly switching between them!
MrJoshW
Jun 19, 2019NETGEAR Employee Retired
Hello,
In regards to the SSID issue displaying multiples of the same SSID. Is it displaying duplicates of both the 2.5 and 5ghz frequencies? Does it remain or does the duplicate SSIDs disappear after some time?
- ThaMichieJun 19, 2019Tutor
Hi,
It's displaying duplicates and they do not disappear. It only affects Wifi 2 on firmware 2.3.1.100.
Downgrading to the previous firmware fixes this issue.
- schumakuJun 20, 2019Guru - Experienced User
ThaMichie wrote:Since I upgraded to 2.3.1.100 Orbi sends out 2x the same SSID of network 2.
Complete unclear - where and how do you see the same SSID multiple times and/or where do you see duplicates?
- ThaMichieJun 20, 2019Tutor
I don't understand how difficult this can be...
Like I already said 2 times but will list the same info 1 more time:
1. All wifi devices show the SSID of wifi 2 (Employee network) duplicate and keep switching between both. (It's sending out the same SSID 2 times).
2. 2.4Ghz and 5 Ghz seperation is DISABLED.
3. I'm on firmware 2.3.1.100 where this bug happens, when I downgrade my wifi devices just show 1x the SSID of wifi 2 a,nd stay on it.
4. Resetting the devices or upgrading after the downgrade just presents the same bug.
It's completely clear for me that this is has something to do with the introduction of the 2.4ghz / 5ghz seperation feature as the previous firmware does not have the same behaviour.
Screenshot of my phone attached.
