CHCarlos
Feb 25, 2024Guide
Firmware Version 4.3.2.100 BUG
Hi all
What's about this problem. I sink I have the same issue.
Is an update on the queue?
Kind regards
Carlos
- Apr 04, 2024
The 4.3.3.200 Release notes show
- Fixes an issue where the device that is connected on Ethernet to SXR80 or SXS80 does not come UP for approximately 30 seconds.
Could this be the DHCP issue or connection delay you experience?
Mar 01, 2024Guru - Experienced User
What orbi model # are you referring too?
Need more details on what this problem is?
CHCarlos wrote:
Hi all
Kind regards
Carlos
- CHCarlosApr 04, 2024Guide
Hi,
Sorry for the delay.
I have the AX6000 WIFI Mesh Router (SXR80) with to satelites SXS80.
The problem is that the DHCP Request from PC's LAN wired are very slow 10-30s.
This problem is coming with the news firmware release.
Kind regards
Carlos
- FURRYe38Apr 04, 2024Guru - Experienced User
What is the brand and model# of the ethernet adapter in the PCs?
Be sure any ethernet adapter drivers are up to date from the ethernet mfr.
- schumakuApr 04, 2024Guru - Experienced User
How are these PCs resp. the LAN connected to the SXR80 or to the SXS80? How are the port(s) and switches/switch ports configured?
Referring to the 4.3.2.100 from the subject line? SXR80 / SXS80 Firmware Version 4.3.3.200 is out since about one day as of writing. What does e.g. https://www.wireshark.org/ "see" (just with the dhcp filter) when the LAN systems are requesting DHCP?
