CHCarlos's avatar
Feb 25, 2024
Firmware Version 4.3.2.100 BUG
Hi all What's about this problem. I sink I have the same issue. Is an update on the queue? Kind regards Carlos
  • schumaku's avatar
    schumaku
    Apr 04, 2024
    The 4.3.3.200 Release notes show
    • Fixes an issue where the device that is connected on Ethernet to SXR80 or SXS80 does not come UP for approximately 30 seconds.
    Could this be the DHCP issue or connection delay you experience?
