BooJangles
Jan 27, 2021Apprentice
FW 2.6.0.108 Deletes Address Reservations on Reboot
Performed update and lost all existing IP address reservations. Set them back up manually and will work until you perform a reboot and they are all lost again.
RaghuHR
Jan 28, 2021NETGEAR Expert
Hi BooJangles
Are you managing your Orbi Pro devices via Insight? Address reservation is supported from Insight so you can use Insight to configure address reservation.
Thanks,
Raghu
BooJangles
Jan 28, 2021Apprentice
Whether I use Insight or Browser when local the reservations delete after a reboot.
- RaghuHRJan 28, 2021NETGEAR Expert
Thanks BooJangles for confirming. We are working on a fix for your issue. Will update you ETA as soon as we know.
Raghu
- BooJanglesJan 28, 2021ApprenticePlease test the fix staying intact after a config restore. I have confirmed currently the reservations will show briefly after restore but then disappear once the system is fully up.
I made a backup with all the reservations so I hopefully don’t have to recreate them all manually.
Thanks - BooJanglesJan 28, 2021ApprenticeRaghuHR
I think this has already been mentioned in other threads but the client list randomly goes to zero on Insight mgr and the Satellite list randomly shows satellites offline (they are online). - BooJanglesFeb 15, 2021Apprentice
