BooJangles
Jan 27, 2021Apprentice
FW 2.6.0.108 Deletes Address Reservations on Reboot
Performed update and lost all existing IP address reservations. Set them back up manually and will work until you perform a reboot and they are all lost again.
JohnD333
Feb 24, 2021Apprentice
Ditto for OrbiPRO Wifi6 (SXR80 SXS80)
I believe that reservations worked properly (were kept on reboot) until the firmware update prior to 3.2.1.102, but not certain.
With Wifi6, restoration from backup reserved IP’s are not restored - there is an empty reservation list.
Does not matter if the IP reservation is made via Insight App, Incite portal on PC, or direct on browser web interface ____._____._____.1.
Hope Netgear is working on this too.
RaghuHR
Feb 25, 2021NETGEAR Expert
Hi all,
We are workiing on this issue. Will keep you updated.
Thanks,
Raghu
