virtudude
Nov 16, 2022Aspirant
Internet access from wired clients being throttled on SXR80
I have a SXR80 along with the satellite and I was previously had all of my wired devices plugged directly into the ethernet ports on the satellite. I had no problem getting my full broadband speed (1...
DaneA
Nov 22, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
I recently swapped the router and the satellite so now those same devices are plugged directly into the router.
Is the SXR80 configured as Router Mode and its directly hardwired to the router? If yes, then you have a Double NAT scenario. To learn about Double NAT, kindly access the article below:
What is double NAT and why is it bad?
DaneA
NETGEAR Community Team
