S1urf's avatar
S1urf
IOS device seem to drop out when moving between areas - SRR60
Have one orbi pro SRR60 and three SRR60 satellites all with latest firmware V2.5.4.104.
Initially, wirelessly connected but now wired. My IOS devices with IOS 14.0.1 on don't seem to stay connected as I move around the home. I have to turn Wi-Fi off and on again on the iPad or iPhones.
this problem also happened on previous firmware, noticed other netgear mesh systems seem to have reported similar issue so just thought I would ask if anyone had a solution before I throw them all out
cheers
Steve
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    S1urf,
    We apologize for the inconvenience this has caused you.  Is the problem only observed on iOS devices?  How about on Android devices and Windows PC/laptops, is it the same problem as well?
    DaneA
    NETGEAR Community Team
    • S1urf's avatar
      S1urf
      Hi
      I only have Macs iPhones and iPads in my environment, no android or PCs so I cannot say whether the fault relates to anything else
      sorry
      steve
  • DaneA's avatar
    DaneA
    @S1urf,
    Thank you for your response. Was everything fine before you have upgraded the firmware to v2.5.4.104?
    Kindly try to factory reset the SRR60 and three SRR60 then reconfigure everything from scratch. Observe if the same problem will recur.
    If still the same problem, I suggest you to open a support ticket with NETGEAR Support here as soon as possible for further technical assistance
    DaneA
    • S1urf's avatar
      S1urf
      HI DaneA
      thanks for your help, it was on previous firmware, will try your suggestion although it will be a few days before I can do the reset
      cheers
      steve
ProSupport for Business
