tehBob
Oct 25, 2022Aspirant
IoT network not DHCPing anymore
Let me preface this by saying I live in Texas, where our power grid goes down as often as the sun does. With that being said, last night there was a strong gust of wind that knocked out my power fo...
JeraldM
Oct 31, 2022NETGEAR Employee Retired
Welcome to the community!
Just to confirm, have you also tried disabling then re-enabling the VLAN on Wireless 3?
Please refer to page 86 of the user manual here on how to do so.
JeraldM
NETGEAR Community Team
tehBob
Nov 02, 2022Aspirant
Yes, I did try doing that as well. My final fix was to fully shut down everything for an hour. No internet, no router, no anything for a full hour. Once plugging everything back in, DHCP started to work again. This is not a solid fix for the future, but it worked for the time being.
- architeNov 03, 2022Star
I think you ultimately performed the steps outline in the release notes at the bottom of the Known Issues.
Based on the limited info in the Known Issue, I'm assuming there is some race condition taking place where the DHCP service or iptables rules are set before the vlan interface has been created. Enabling telnet access through the debug page can help you recover if you have some linux knowledge. Personally though, I have up on DNS and DHCP on my SX(R/S)80 and instead have a raspberry pi connected via a trunk port handing out addresses on all the VLANs. The main reason was to be able to have DNS for all DHCP hosts.
I have not experienced this issue though so maybe it's just a buggy DHCP server/config? I attached my dnsmasq config and ubuntu core netplan config incase anyone else wants to try and see if it helps.
dnsmasq.conf
domain-needed expand-hosts localise-queries bogus-priv no-resolv server=/test/ server=/localhost/ server=/invalid/ bind-dynamic cache-size=10000 conf-dir=/etc/dnsmasq.d/,*.conf domain=lan dhcp-authoritative dhcp-leasefile=/etc/dnsmasq.d/dhcp.leases localise-queries dhcp-range=192.168.1.100,192.168.1.199,8h dhcp-option=3,192.168.1.1 dhcp-range=eth0.20,192.168.20.100,192.168.20.199,8h dhcp-option=eth0.20,3,192.168.20.1 dhcp-range=eth0.30,192.168.30.100,192.168.30.199,8h dhcp-option=eth0.30,3,192.168.30.1 dhcp-range=eth0.40,192.168.40.100,192.168.40.199,8h dhcp-option=eth0.40,3,192.168.40.1
netplan.yaml
network: ethernets: eth0: addresses: - 192.168.1.2/24 gateway4: 192.168.1.1 nameservers: addresses: - 127.0.0.1 version: 2 vlans: eth0.20: addresses: - 192.168.20.2/24 id: 20 link: eth0 eth0.30: addresses: - 192.168.30.2/24 id: 30 link: eth0 eth0.40: addresses: - 192.168.40.2/24 id: 40 link: eth0
