Bnjmn22
Sep 20, 2022Aspirant
Is VLAN Tagging supported yet?
Hi, My ISP CenturyLink requires VLAN tagging for incoming packets. Does the SXK80 / Orbi Pro support it yet, or do I have to install a beta firmware still?
Bnjmn22
Yes, I just upgraded to V4.2.2.130. Where do I set all external / incoming traffic to VLAN tag 201?
Thank you.
capin
Sep 29, 2022Tutor
Under Advanced -> Advanced Setup -> VLAN / Bridge Settings, I created a vlan named internet with a VLAN ID of 201 and network and client isolation turned on.
I assigned this vlan profile to my WAN port and it worked with CenturyLink fiber.
Also under internet setup I set the ISP to PPPoE and entered the login and password with connection mode always on.
This is firmware version V4.2.2.130 on SXR80 hardware.
