Tremolux66
Mar 19, 2024Tutor
Monitoring multiple Orbi networks
I monitor multiple Orbi networks with the iPhone app, one local and one remote. When I get an alert, it’s not always obvious which network it came from. It would be very helpful if the router hostname...
michaelkenward
Mar 19, 2024Guru - Experienced User
I do something similar. I ensure that each network has a different name.
I can even manage two routers in one network, an AP and router.
- Tremolux66Mar 19, 2024TutorThe router names are different, but that doesn’t help if the name is not displayed (main screen, alerts). I can tell which network I am looking at on the main screen because the local network has 1 satellite and the remote has 2. But when looking at an alert or report, there’s no indication of which network it is. At a minimum have to go to the menu to see, which is okay for the main screen, but inconvenient (and potentially confusing) elsewhere.
