Tremolux66
Mar 19, 2024Tutor
Monitoring multiple Orbi networks
I monitor multiple Orbi networks with the iPhone app, one local and one remote. When I get an alert, it’s not always obvious which network it came from. It would be very helpful if the router hostname...
michaelkenward
Mar 19, 2024Guru - Experienced User
I do something similar. I ensure that each network has a different name.
I can even manage two routers in one network, an AP and router.
Tremolux66
Mar 19, 2024Tutor
The router names are different, but that doesn’t help if the name is not displayed (main screen, alerts). I can tell which network I am looking at on the main screen because the local network has 1 satellite and the remote has 2. But when looking at an alert or report, there’s no indication of which network it is. At a minimum have to go to the menu to see, which is okay for the main screen, but inconvenient (and potentially confusing) elsewhere.
