yazun
Sep 16, 2021Aspirant
NAT loopback _not working_ on SXS80 Satellite.
Hello, Contrary to some information from this forum we cannot get loopback NAT working on SXS80. It does work while connected to the main router (SXR80) but it is ridiculous one has to be connecte...
ynghill
Dec 20, 2021Tutor
Hello
i have the same problem with NAT loopback on local net i can not use my internet adress.
my fw= 3.3.0.122 the same on satellites 3pc.
Is it possebility to get the beta fix to.
ynghill
Dec 21, 2021Tutor
I find more exact my problem: if connect to wifi NAT works on lan not.
My satellite have not so strong signal so i connect with lan and then NAT stop work.
Can i miss som settings or is it fw problem?
- yazunJan 11, 2022Aspirant
No solution so far.
Netgear promised fw fix for this year, but we shall see...
- DaneAMar 15, 2022NETGEAR Employee Retired
SXR80/SXS80 Firmware v4.0.0.118 has been recently released. This fixes the NAT loopback issue if clients connect to the satellite. You can download it as well as read about its new features, bug fixes and security fixes on this link.
DaneA
NETGEAR Community Team
