Bnjmn22
Feb 26, 2022Aspirant
Need help with Vlan tagging for sxs80 wired backhaul
Hi, I have Century Link fiber. My Orbi RBK853 worked fine with wan Vlan tagging for both the router and satellite. However, I had to switch to the Orbi Pro system for the multiple VLAN ssid func...
Bnjmn22
This is what my VLAN / Bridge settings look like now.
It works, but problem is that I think now its in wireless mode as the connection is rated as "fair" and my ping/speed seems slower than my RB853
Bnjmn22
I found the exact same problem someone else was having. https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/Help-on-configuring-Wired-ports-for-Internet-access-via-Employee/m-p/2177374
I'm also on CenturyLink that requires a 201 tag VLAN, which is why my WAN is set to 201.
Is there no other solution but buying an extra switch?
What is the new beta firmware solution?
I have the new beta firmware installed.
- Bnjmn22Feb 26, 2022Aspirant
Update,
I installed the new 4.0.0.118 firmware and I see the Bridge/VLAN tag I was using is gone. Now, there is an IPTV one I set to 201, and then I set the WAN back to 1/default and it does not connect to internet. However, when I set WAN to 201, a custom ID I created, it works but the satellite is not working again.
Also no lan ports are connecting to the internet either.
Ok, so now I have the second port set to the IPTV VLAN (set to 201). This port, on the router, is hardwired to my satellite (port 1) for backhaul. Its working again similarly to how Bridge/VLAN was working.
However, this is because it is now wirelessly backhauling. I have confirmed this by unplugging the satellite. Also wired LAN ports on the router cannot access internet. It seems like VLAN tagging can only be set to one port at one time?
Can someone provide clarity? Is having an external switch like the GS105Ev2 set to 201 tagging, the only real solution?
I thought the beta firmware would have a fix :) my family is starting to hate me working non stop on the weekend on this.
- DaneAFeb 28, 2022NETGEAR Employee Retired
Welcome to the community! :)
Just found out that the community member, JoeJoeJoeJoe, from this thread was given a beta firmware by the higher tier of NETGEAR Support. It might be different from the beta firmware version you are referring to that you have uploaded to your SXK80.
Since you have already uploaded the official latest firmware version that was recently released, let us try to perform a factory reset on your SRK80 then reconfigure the settings from scratch and check if you will encounter the same problem.
DaneA
NETGEAR Community Team
- Bnjmn22Feb 28, 2022Aspirant
Yes, I did a factory reset and it is still not working, so maybe it is a different beta.
As an update to this thread, I bought an external netgear switch GS105Ev2 and I tagged the in-coming traffic on port 1/2 and connected port 1 to my CenturyLink fiber and port 2 to the SXR80 and that fixed the issue. It does require an extra physical hop/cost which is not ideal given the RBR8530does this inside the router itself.
