LourensK
Feb 19, 2021Follower
Netgear orbi pro srk60
Which app can I use with the netgear orbi pro srk60? I have downloaded the android app, but it doesn't work? You have the insight app and the normal app (android) Which for which system?
schumaku
Feb 20, 2021Guru - Experienced User
The Orbi App is for the consumer Orbi systems.
The Insight App can be used - with a different function set than the above - on the Orbi Pro and Orbi Pro WiFi 6 system.
