sovereign323
May 27, 2022Aspirant
Netgear Orbi Pro SRR60 not showing all attached devices
I have the Netgear Orbi Pro SRR60, 1 router SRR60 and 1 satellite SRS60. I have the latest firmware V2.7.0.122 installed. The attached devices is still not working properly. There are still devi...
sovereign323
May 31, 2022Aspirant
Netgear not even going to bother to reply ?
I just noticed now DDNS also never works. The response when clicking on show status under Dynamic DNS settings:
No update action. There is no IP address on the Internet port.
That is just garbage. There is most definitely an IP address on the internet port.
Disabling DNS and re-enabling it fixes it again, but that kind of defeats the purpose of Dynamic DNS. How will I access my devices remotely if my IP is not updated at the DDNS provider when it changes on the router. I see this is a very common problem on Netgear devices.
DaneA
May 31, 2022NETGEAR Employee Retired
Let us try this. Kindly update the firmware to v2.7.1.108 then observe if the same issue occurs. You can download firmware v2.7.1.108 here. If ever the same problem happens, kindly open a support ticket with NETGEAR Support here at anytime for further investigation.
DaneA
NETGEAR Community Team
