FURRYe38's avatar
New - SXR80 / SXS80 Firmware Version 4.3.3.200 Released
Bug Fixes: 04/03/2024
  • Fixes an issue where the device that is connected on Ethernet to SXR80 or SXS80 does not come UP for approximately 30 seconds.
  • Fixed the delay in updating the Attached Device details in SXR80.
  • Fixed the accessibility of SXR80/SXS80 admin page using Chrome browser.
  • Fixes an issue where the user unable to access SXR80 when its LAN interface is assigned with 10.0.0.1 IP address.
Known Issues:
  • Removes remote access for security reasons.
    Workaround: Consider becoming a NETGEAR Insight subscriber so that you can enjoy remote management with built-in security features like automated security alert notifications, two-factor authentication, Single Sign-On (SSO), and Multi Pre-Shared Key (MPSK).
  • After updating the router firmware, existing clients can be steered to the router because the wireless readiness in the router is faster than the wireless readiness in the satellite.
    Workaround: Connected clients might notice slower throughput or a weaker signal, which resolves when the user roams or reconnects.
  • WPA3-Enterprise might not work with iPhone 11 (supports 802.11ax) and above on iOS 14 and above.
    Workaround: Do not use WPA3-Enterprise.
  • The device UI can be accessed via the default VLAN network only.
    Workaround: Connect to a WiFi network that uses the default VLAN profile when you want to access the device UI.
  • When the SXR80 router is connected to multiple SXS30 and SXS80 satellites, it is possible that the SXS30 satellite cannot ping the SXR80 router, and the bar LED lights magenta. However, clients can still access the SXS30 satellite and the Internet.
    Workaround: Reboot the SXS30 satellite and the SXR80 router.
  • When the SXR80 router is connected to multiple SXS30 and SXS80 satellites, wireless clients that connect to wireless network 3 with the VLAN feature enabled cannot access the Internet.
    Workaround: Reload the wireless configuration or disable the VLAN feature on wireless network 3.
Download Link:
https://www.netgear.com/support/product/sxk80#download
Firmware Update Instructions:
If the Orbi Pro is connected to the Insight cloud, perform a firmware update through the firmware schedule policy, or manually perform a firmware update using the Insight app or local browser interface.
To update the Orbi Pro firmware from router web interface, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click Documentation on the product page. We highly recommend updating the satellite firmware first, and then updating the router firmware.
After updating to the latest firmware, make sure to update your version of the NETGEAR Insight app for the best functionality and user experience.
This article applies to:
1 Reply
  • FURRYe38's avatar
    For anyone with a Orbi Pro SXK80 system, SXR and SXS, and out of warranty and would like an alternative to NG stock FW:
    OpenWRT 24.10 has official support for Orbi Pro SXK80
    Just got released: https://downloads.openwrt.org/releases/24.10.0-rc1/targets/qualcommax/ipq807x/
    Any use, support and technical information needed regarding OpenWRT, please review and consult with there OpenWRT support and forum regarding information.
    Good Luck.
ProSupport for Business
