Mstrbig
Oct 03, 2021Master
NEW SXK80 Firmware version 3.3.0.122 notification false or missing
This morning I received an email for new firmware upgrade, for my SXK80 system. Either there was a problem and Netgear pulled the updates, or there is a malfunction on their website, because when y...
- Oct 04, 2021
I can't believe I didn't try that. Thanks for the info! Also just fyi looks like they fixed the links from the main download page: they now properly contain the .zip extension the above poster pointed out.
quagmire1
Oct 03, 2021Luminary
The "not found" is just because of a typo in the links. If you append ".zip" to the supplied links, they will work.
The correct links (which I found in the release notes):
SXR80: https://www.downloads.netgear.com/files/GDC/SXK80/SXR80-signed-V3.3.0.122.zip
SXS80: https://www.downloads.netgear.com/files/GDC/SXK80/SXS80-signed-V3.3.0.122.zip
Architekt
Oct 04, 2021Apprentice
