Theok
Feb 08, 2024Tutor
Not sure what is EOL on the webpage for SXK50
Orbi Pro SXK50 | WiFi 6 System | NETGEAR Support On the above page it shows that "This product/software is end-of-life." Not sure if this is referring to the hardware or software (Insight Pre...
ReneD
Mar 06, 2024NETGEAR Moderator
Hello Theok,
And welcome to the NETGEAR Community! 🙂
End of Life means the device will no longer be available over the market but does not mean your warranty for hardware and support will be forfeited. Warranty starts the time you purchase and register the product. Usually for an Orbi Pro, it has a 5-year hardware warranty. Units that has been proven defective can be replaced with the same device from support within the duration of the 5-year hardware warranty. However there are different types of support warranty. Netgear gives a phone support warranty for only 90 days but should have the same duration of email or chat support warranty from how long your hardware warranty is. If there are issues on the software or firmware, more likely a patch firmware will be released after Engineering investigation even if the device is EOL. And if the issue is with security vulnerabilities, you may want to report it at Netgear security on the link below. You may want to earn extra income out of reporting a vulnerability on your Netgear device.
https://www.netgear.com/about/security/
Have a lovely day,
Rene D
Netgear Team
