chadonmac
Jan 09, 2021Initiate
Orbi firmware V2.6.0.108 no longer allows Orbi App connection
I let the Orbi insight app update my router and satelites to V2.6.0.108 and now i am unable to connect to my network through the local Orbi App. I have tried all troubleshooting steps(I could connec...
btrogdon
Jan 09, 2021Aspirant
I read that the New Firmware was for SRR60 only and release notes said not to apply to Satellites.
To my question, how can I upgrade Router to latest version? I cannot even find it.
-Brad
Networksniffer
Jan 09, 2021Guide
Hi Brad
It synced automatically with my SRR 60 and SRS60. The problem with the firmware is reconnection from the software of the app.
The syncing is only a problem with the SRC60.
Thanks
Pascal.
Thanks
Pascal.
- DarkVisaJan 09, 2021Tutor
Hi,
I have not problem syncing - just that the app doesn't connect anymore
- YeZJan 09, 2021NETGEAR ExpertWe had issue with SRC60 firmware 2.6, so it was not released this time in IM 6.0 release, it will come later.
For users who have SRC60 and had issue syncing with SRR60 running 2.6 firmware, you can download SRR60 router 2.5 firmware from support.NETGEAR.com and downgrade SRR60 to 2.5.- schumakuJan 09, 2021Guru - Experienced User
YeZ wrote:
For users who have SRC60 and had issue syncing with SRR60 running 2.6 firmware, you can download SRR60 router 2.5 firmware from support.NETGEAR.com and downgrade SRR60 to 2.5.Is this also the work-around suggested for the subject Orbi App connection failure?
