Matthewd78
Apr 04, 2021Aspirant
Orbi Pro generating 10.0.0.## IP addresses for all devices
Hi, I am hoping someone can help with my IP issue. Due to the number of devices on our home network and our preference to have designated wireless networks for kids and visitors, we chose to go with...
JohnD333
Apr 05, 2021Apprentice
Matthew,
How are you managing your router? Insight web portal via browser, insight app. Orvia browser 10.0.0.1?
Not certain you can change 10 to 192 on the App once set up, but you can on web portal and the 10.0.0.1 method. Both are under advanced setup/LAN setup. If you change the 10 to 192, and save, router, all the satellites will reboot and you will need to toggle the WiFi on and off or shutdown or unplug all devices to get new ip addresses. HOWEVER, if you do not know what you are doing, leave the 10 alone, and simply use the app, web portal or 10.0.0.1 process/Connected devices to find the ip of the assigned device you want to talk to. Then on browser enter that up address and probably the next screen will ask for ID and password for that device.
If you do know what you are doing and really want to change the LAN/TCIP from 10.0.0.1 to 198.168.0.1 make sure you ALSO change the router starting address from (probably) 10.0.0.2 to 192.168.0.2
Now the other basic question is whether you are running Lan separation for the IoT devices. I have the SXR80 and says so I may be different. On that setup, normal devices/traffic is on the 192.168.0.1...., and IoT devices/traffic
are on 192.168.30.1 with start range for devices at 192.168.30.2.
While you can “see” what is connected to what on the web portal, app, and 10.0.0.1 browser page /attached devices, For your pc/device to see/connect to/configure something connected to the ...30 LAN, your pc/device must be connected to that .... 30 WiFi signal. Except for those control/setup pages/app, if your pc/device is on ....1 you won’t be able to see .... devices connected to ...30. Again, this is on the proWifi6SXR80 system and may not be applicable for how you are managing IoT’s.
The above should get you running. Hopefully someone with your setup will get you further down the road.
John
John
