lostgear
Mar 09, 2023Star
Orbi Pro Mini includes Satellite as Attached Device even if wired to router
The Orbi Pro Mini Satellite is wired via Ethernet + switch to the same network as the Router (in Access Point Mode). But in the web interphase under Attached Devices the satellite appears under "...
BruceGuo
Mar 15, 2023NETGEAR Expert
If 2 routers (SXR30) are connected, both need to be in "router" mode. If one of them is AP mode, it would have some problems.
lostgear
Mar 15, 2023Star
Sorry there is just one SXR (in AP mode) and a Satellite. I just separated the ports for clarity.
So it should be:
Gateway---->Router---->(wan port)-SXR -(LAN port)--->Switch----satellites?
Although I tried with LAN port in SXR as well but same results.
