AllanA's avatar
AllanA
Guide
Oct 01, 2019
Orbi Pro SRK60 Envirnment
I'm running an Orbi Pro SRK60-100 NAS router with 5 satellites without issue. The nature of our building construction necessitated the need for 5 satellites and will likely require the use of two or ...
  • AllanA's avatar
    AllanA
    Oct 03, 2019
    Thanks. I think 8 should be plenty, but as always I'll probably push the envelope a bit if/when the need arises.
    Are there wall plug repeaters available to Orbi Pro? Perhaps for odd corners where only a few people work a wall plug signal extender would do the trick?
ProSupport for Business
