AllanA
Oct 01, 2019Guide
Orbi Pro SRK60 Envirnment
I'm running an Orbi Pro SRK60-100 NAS router with 5 satellites without issue. The nature of our building construction necessitated the need for 5 satellites and will likely require the use of two or ...
- Oct 03, 2019
Thanks. I think 8 should be plenty, but as always I'll probably push the envelope a bit if/when the need arises.
Are there wall plug repeaters available to Orbi Pro? Perhaps for odd corners where only a few people work a wall plug signal extender would do the trick?
AllanA
Oct 03, 2019Guide
JohnC_V
Oct 04, 2019NETGEAR Employee Retired
I don't think that wall adapters would be applicable to Orbi Pro. It would be best if you will create a thread on the WiFi Adapters community to get the right information. If ever your concern is addressed or resolved, feel free to close the thread by clicking the "Accept as solution".
Thank you!
John
NETGEAR Community Team
- AllanAOct 04, 2019Guide
I was under the impression that they wouldn't as well. Still those types of devices would really help for the odd locations where there are only a few people needing access. I'll check in that thread. thanks!
