Retired_Member
Sep 26, 2021Orbi Pro SRR60 DoS attack: STN/ACK Scan
Hi, Is is normal to see in the Logs (Advanced/Administratio/Logs) to see a lot of dos attack showing up? And is there ways to stop it? Ans is router/WAN proteced? Below is a copy of what ...
schumaku
Sep 27, 2021Guru - Experienced User
Absolute normal router operations. The router protected certain activities on Internet -> Router/Internal Network activities. Some are side effects of devices with a lot of active connections to the Internet are going to sleep, roam away from the local WiFi or wired connections to the mobile network, roam from the mobile to the local WIFi, and so on.
Retired_Member
Sep 27, 2021Thank you schumaku much appreciated...
