BuckeyeDan
Nov 11, 2020Tutor
Orbi Pro SRR60 not showing clients after 2.5.4.104 firmware update
Since updating our SRR60 router with 4 SRC60 sattelites to firmware 2.5.4.104, connected clients do not show up on the Insight App or Insight Portal. They are displayed on the router interface. Any...
BuckeyeDan
Nov 20, 2020Tutor
I had one of our wireless clients disconnected from the SSID and reconnected but it still does not show up on the app or portal.
But it's not just wireless clients that are not showing up it's wired and wireless. Currently we have 10 wired clients and 63 wireless clients that show on the router interface but none of them show up as a connected client on the app or portal.
The app is updated to version 5.11.19.
Thanks,
Dan
DaneA
Nov 23, 2020NETGEAR Employee Retired
I suggest you to open a support ticket with NETGEAR Support here at anytime for further investigation.
DaneA
NETGEAR Community Team
- karltjeMar 18, 2021Aspirant
hi, is there any update on this issue?
Today, I got upgraded to Netgear Insight Premium and I do not see any device that is connected to one of my Satellites.
kind regards
- JohnD333Mar 18, 2021ApprenticeKarl,
Neither the Insight app nor the Insight web portal show devices connected to a satellite -all are shown (in Topography) as connected to the router. Also, while some satellites can conceivably be daisy chained to other satellite(s) before being connected to the router, all satellites are shown as connected to the router on both Insight web portal and Insight app.
Many have complained about this and hopefully that will get fixed in the future. For now the only way to see what is REALLY connected to what is to log into the router itself via ___.0.0.1
ID = admin (you can no longer change this if you use Insight)
Password = password (unless you changed it, and you should!).
Any changes you make there will be saved only until Insight wipes them out, reverting to what is in Insight cloud. Insight will do that any time you reconfigure or reboot the system via Insight. If there is any good news it is that both the Insight web portal and the Insight app use the same cloud database.
Firmware updates are often seen and accessible on Insight long before seen on the ____.0.0.1. However, the success of early firmware update adopters has been spotty.
Welcome. Hood luck.- karltjeMar 18, 2021Aspirant
Thanks a lot John,
So, if I understand correctly:
- It is better to not change anything directly via ...0.1, since it will be anyway overwritten by what's in the insight database, once you change anything in insight or do a reboot.
- When looking at the topology, I only see Internet -- Orbipro router -- satellites. I do not see any device directly connected to the router.
kind regards.
- geekworldApr 15, 2021Aspirant
I have been having the same issue since 2.5.4.104
Was hoping that 2.6.2.200 was going to fix it, but it did not.
None of the health data and none of the connected devices are synchronizing with Insight. This is frustrating, because it was working fine at the beginning, then a firmware broke it last summer, then it was fixed until last November 2020. Since then broken again.
At the moment the Orbi Pro is not Pro at all.
The local Orbi Pro log is totally flooded with [Insight] errors. Some examples are below:
[Insight] Failed to post health data. r = -1, Thursday, April 15, 2021 18:06:10
[Insight] Failed to make request. url = https://presence.insight.netgear.com/insightdevcom/pr, Thursday, April 15, 2021 18:06:10
[Insight] Failed to post monitoring data. r = -1, Thursday, April 15, 2021 18:05:46
[Insight] Failed to call im_dev_monitor., Thursday, April 15, 2021 18:05:46
[Insight] Failed to make request. url = https://monitor.insight.netgear.com/orbi, response_co, Thursday, April 15, 2021 18:05:46
[Insight] Received xagent notification. message = rapid., Thursday, April 15, 2021 18:04:29
[Insight] Failed to post monitoring data. r = -1, Thursday, April 15, 2021 18:03:11
[Insight] Failed to call im_dev_monitor., Thursday, April 15, 2021 18:03:11
[Insight] Failed to make request. url = https://monitor.insight.netgear.com/orbi, response_co, Thursday, April 15, 2021 18:03:11
[Insight] Failed to post health data. r = -1, Thursday, April 15, 2021 18:01:54
[Insight] Failed to make request. url = https://presence.insight.netgear.com/insightdevcom/pr, Thursday, April 15, 2021 18:01:54Please provide a fix asap.
Thanks
- DaneAApr 26, 2021NETGEAR Employee Retired
It would be best that you to open a support ticket with NETGEAR Support here as soon as possible for further investigation.
DaneA
- Retired_MemberMay 27, 2021
I likewise have found this terribly frustrating. If anyone gets a response from Netgear support, please post here.
At this point, the Insight app and portal are useless for me.
