jonesy_chi
Jul 06, 2021Follower
Orbi Pro SXK80 - 3 story building with router on 1st floor and satellite on 3rd?
I recently purchased the Orbi Pro SXK80 with 1 satellite for a new home being built. The house has a basement with 3 floors and a rooftop. I'm wondering if I'll be able to get by with the router on th...
Jul 06, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Be sure to avoid putting the RBR in a basement. Concrete and steel whill inhibit wifi signal travel.
