lollodc
Sep 07, 2023Aspirant
Orbi pro sxr30 lost Connection in ap mode with pfSense router
Hi, I have some trouble with the sxr30 configured in ap mode, after a couple of hours lost connection with the magenta light. Sometimes reset work sometimes no. I have a pfSense router (I'm new i...
- Nov 08, 2023
Small update, I solved my issue with reading the following discussion: https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Why-does-blocking-ICMP-cause-constant-Orbi-reboots/m-p/2319088/highlight/true
Opnsense is blocking the ping by default, which makes the orbi system to reboot constantly.
Allowing the icmp on the firewall solved my problem. I guess it's the same for the pfsense firewalls.
Hope it helps
Sep 07, 2023Guru - Experienced User
A bit more details on how this is ran would help.
It should go:
modem----pfsense router----SXR30 (ap mode)---->Satellites
The satellites have to come after the sxr30 and be linked through its lan
And the pfsense router should connect to the sxr30's wan port.
so how is your actual setup wired and to what ports?
lollodc
Sep 17, 2023Aspirant
thanks in advice.
My current setup is: ont -> pfSense router -> orbi in ap
The pfSense router is needed because there is no way to setup the Italian Vodafone fiber with the orbi router.
I don't know why the orbi after some time go magenta. the orbi router is connected directly to the pfSense router. Now for make wifi working i put an old router and power off the orbi router. is strange that the wired satellite work in this situation.
- FURRYe38Sep 18, 2023Guru - Experienced User
I'd check the pfSense router. Possibly that router is blocking too much traffic or not getting something to the SXR or data is not flowing right from that router.
- makeitsimplebeSep 22, 2023Aspirant
hello
Just wanted to share almost the same experience this week with RBR850 & RBS850 devices having problems after replacing the existing firewall with an Opnsense (a fork of Pfsense).
Symptoms: wifi disconnection every 5 minutes, magenta leds on devices... And no problems when I set the previous device back.The firewall rules are not blocking the outside traffic yet. I have not found yet the root cause of this issue.
I'll try a new attempt later and give feedback
- lollodcSep 22, 2023Aspirant
Do you have any VLANs configured?
there are no blocking rules. it was the first thing I did. I did a basic configuration. Now I tried to disable the second interface linked to the vlan and it has been working for a day. in this case is a problem because I need a vlan for the server and the smart home.
