Fa_IT
Oct 11, 2022Follower
Orbi Pro SXR80 Guest WiFi
I’ve setup the Orbi Pro guest portal for VLAN5, the issue is that the guest who will connect to guest WiFi Portal can still access devices on the main network.
I’ve checked the boxed for both client and network isolation from VLan/Bridge settings for guest wifi VLAN.
Scenario:
- Main Network: 192.168.42.x
- Getting IP: 192.168.1.x from Orbi Pro WiFi
- IP from guest portal: 192.168.50.x
Now both 192.168.1.x and 192.168.50.x can access printer in 192.168.42.x
I don’t mind internal access from 192.168.1.x however Guests should not have access to main network 192.168.42.x and/or devices on it.
1 Reply
