georgedk
Apr 04, 2022Follower
pairing SXK80 system with sxs30 satellite
can a sxk80 system pair with a sxs30 satellite? and if so, will the mesh bandwidth be throttled to the sxs30 max bandwidth?
1 Reply
If you're on new enough firmware it should. As of the .118 firmware, the release notes show they pair.
https://kb.netgear.com/000064664/SXR80-SXS80-Firmware-Version-4-0-0-118
The SXS30 will have lower throughput because its a dual band and not a triband. The tribands have the dedicated backhaul that prevents throughput drop. The dual bands have to use the same band for router---satellite communication and satellite---device communication and can't do both at the same time.
