LarsA
Dec 16, 2019Aspirant
Orbi pro set up for google home
How to set up Orbi pro so it's working with google home, with the regular Orbi it's not any problem, but with the Orbi pro google home lose the wifi signal frequently.
- Jan 02, 2020
Hi, as I was informed by the Swedish netgear suport team that I can`t use google home with Orbi pro, did I return my home assistant to the store again, so I can`t produce any report to you. I will close the thread for now. I will try a new google home assistant later on.
LarsA
Jan 02, 2020Aspirant
nmhTester
Jan 03, 2020NETGEAR Employee Retired
Just to conclude,
OrbiPro will support all the standard 802.11 (Wi-Fi) clients.
apologies for any confusion created.
Thank you everyone for bringing this to a closure.
