ThomasNorway
Dec 22, 2023Aspirant
Orbi SXR80 and IPTV from ISP Telenor
Hello We experience problems with IPTV provided from Telenor, wich is a Norwegian ISP which also delivers IPTV via a box connected to internet. The TV box is connected to a Orbi satallite with...
schumaku
Jan 04, 2024Guru - Experienced User
ThomasNorway wrote:
So, with your suggested configuration as described below, I need to plug the TV box directly to the router on the assigned port?
Yes, this is the only approach I can see currently.
ThomasNorway wrote:
The problem with that, is that the router is located on the 1st floor, and the TV box is on the 3rd floor.
See arrangement below.
Would love to suggest a better solution 8-) Operating a slightly more complex network on a similar wiring infrastructure, at the price of using Smart switches, fully supporting IGMP multicast, dedicated VLANs all through the house, including one VLAN for IPTV - this allows me to connect ISP provided TV boxes in each room
ThomasNorway
Jan 04, 2024Aspirant
Thanks again!
Do you think configuration could work?
Telenor can provide a router that they say will work with IPTV.
